DDR3 Memory Recommendations
nathan4b
I'm currently trying to figure out what the best ram combo would be for my system!, below is my current system specs
EVGA 790i ultra
q9450
2x9800gtxs
all I need now is some decent ram, I do plan on doing a very mild OC on the cpu, around 3.2ish
the following ram I currently have access to and are in stock in canada are the following.
1. OCZ DDR3 PC3-10666 / 1333 MHz / Reaper HPC Edition / 4GB (2x2048MB) / Dual Channel - OCZ3RPR13334GK / 6-6-6-18
2. OCZ DDR3 PC3-12800 / 1600MHz / Platinum Edition / Dual Channel / 4GB (2x2048MB) - OCZ3P16004GK / 7-7-7-20
3. Patriot Extreme Performance / 4GB 2X2GB / PC3-10666 DDR3-1333 / CL7-7-7-20 Dual Channel Memory Kit
would option 1 benefit me more since it has lower timings and im only going for a mild oc?
any advice would be greatly appreciated!
thanks.
OCZ OCZ3P16002GK $220 and the just little more expensive OCZ OCZ3P1600EB2GK $225
I would Advise the Super Talent W1600UX2G7 for real OC work $260 or the Team Xtreem TXD31924M1600HC9 if you can get them.
Source: http://www.anandtech.com/memory/showdoc.aspx?i=3045&p=5
Patriot PDC32G1866LLK $254 pretty OK 7-7-7-18 1740 MHz
http://www.pcstats.com/articleview.cfm?articleid=2192&page=6
Curious about this model Super Talent W1800UX2GP $249 7-7-7-21 but up to which MHz extend?
