DDR3-1600 Memory Timings
Proposed system...
Power Supply: Corsair CMPSU-850HX 850W
Motherboard: Asus P6X58D-E
CPU: Intel i7 930
Heatsink: Noctua NH-D14
Memory: 3x2GB DDR3-1600 ???
I'm building a core i7 system and am having trouble choosing a DDR3 triple channel kit. I'm hoping to overclock to 4.0 - 4.2GHz, so should I be going for DDR3-1600 and is the extra ~$70 worth it for CL7 over CL8?
I'm considering the following Corsair kits...
$199.99 ($209.99 - $10 MIR)
CORSAIR XMS3 3x2GB DDR3-1600 TR3X6G1600C8 G 8-8-8-24
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145236
$264.99
CORSAIR XMS3 3x2GB DDR3-1600 TR3X6G1600C7 G 7-7-7-20
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145242
Are there any other modules you'd recommend, keeping in mind the height of the RAM heatspreaders because I will be using a Noctua NH-D14 CPU heatsink (e.g. G.Skill PI seem to be popular but are too high, and Corsair Dominator seem to be the same as the ones I'm considering but with extra heatsinks which would need to be removed anyway).
Thanks!
Thanks for the reply, Cyclone. So DDR3-2000 with looser timings would be better?
Would these be better than the kits I posted?
$201.99
G.SKILL Ripjaws 3x2GB DDR3-2000 F3-16000CL9T-6GBRH 9-9-9-27-2N
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231306
Nice... 2000 at 1.6v with pretty decent timings.
Yeah, I would grab those over either of those 1600 kits any day.
And, yeah, if you do run it at or close to 2000, it will have a lot higher throughput than running with tigher timings at 1600.
