In his Video, Kyle said a 2.67core i7 (920) uses stock memory speed of 1066.
i7's are on a 133 bus with a 20x multiplier, and people find the memory speed based on that 133 fsb. 133x4 (QPI is quad pumped) for 533mhz and ddr is double rate, 533x2 = 1066mhz memory.
savoy: only if you don't overclock. If you OC your 920 from 20x133 to 20x166 = 3.3Gig, your ram multiplier options are 6x166 = 1000, or 8x166 = 1333. If you're running at 20x200 = 4gig, it becomes 1200 or 1600.
Kyle,
what Ram are you considering for this build?
Also will a 1333 tripchan set be able to be overclocked to 1532?
or do you have to use a 1600 set to get the 1532?
I've order my board and cpu but have been waiting for the 8-8-8 timed 1600Mhz sets to be in stock again.
Can you clear this out some for us with your experience on the topic?
thanks,
nikos
can you link us to where you saw the Corsair memory for sale? According to the videos posted i haven't seen the same Corsair memory available yet, just the XMS3 version on newegg
Thanks.
This is the same set I've been waiting for. I kept looking throughout the day...there where nowhere to be found at the wholesale distributors.
some of the distributors didn't even have them sku'd up yet.....
N
Googled the part number that kyle gave:Thanks.
N
So 1.65v is the hard limit on memory right? I'm still doing my research as i wait for the swiftech gtz adapter to become available. I refuse to put a dinky air cooler on a brand new system. So i still have some time to look around and let prices fall on stuff. Also, kyle, what made you decide on the asus board over the evga board. I like my rampage formula and all, but i've heard way too many horror stories about asus rma should anything ever happen.
Funny how it's not the i7s and X58 motherboards that are out of stock.
It seems like DDR3 6GB kits are running out everywhere
I've spent 2 days looking around for decently priced kits and finally found em'
I ordered the Corsair kit from zipzoomfly that Kyle is using, it still says in stock but my order status still says "processing"...I hope they actually have them!!! Just dumped $2400 on newegg for all of my components for a complete i7 system so I am praying the sticks show up friday.
I was going to go with 2 sets of these for 8gb total.. no good?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227286
Those run at 1.9v. For the i7 its supposed to be 1.65v tops. Also for max performance you want tripple channel (3 or 6 sticks)
