hammocksleeper
- Jan 3, 2008
OK Question is:
8600GT 256MB DDR3 or 8600GT 512MB DDR2
they cost exactly the same ($100). and you are building this computer to play CoD4. which is the better choice? - and NO you cannot change the budget which is $100.
If it helps, here is the rest of the computer:
ore 2 duo 2.2ghz (maybe overclocked)
2GB DDR2-800 RAM
SATA 7200rpm 16MB cache buffer hard drive
Dunno what resolution I would be playing at, normal resolution? Most likely looking at a 17" or 19" screen.
thanks guys for reading my first post!
2GB DDR2-800 RAM
