DDR2 on AMD MOBOS?
leSLIe
I want to upgrade my RAM and DDR2 seems nice for overclocking and low latencies
so I was wondering if DDR2, which is NOT OFFICIALLY supported by any AMD chipset (VIA, NVIDIA), can be used on AMD mobos, like nforce4, nforce3 or kt880? chances are that the mobo might need a bios update, but who knows? Have NE1 tried that out?
No it cant, it isnt any greater than DDR for overclocking and the latencies are atrocious compared to good DDR1.
I think amd is waiting either for ddr1 to reach fsb speeds like ddr2 or either ddr2 to get lower latencies. DDR isn't going away any time soon thats for sure.
The rumour is that amd will miss ddr2 altogether and go straight for DDR3, which is even better.
Adn to the OP, my apoligies, wasn't being harsh, just succinct.
You can't. They physically have a different pinout and the memory controller thats integrated with the AMD 64 cores, does NOT support it. Therefore it can't happen without a new processor and new motherboards.
AMD may or may not ever go with DDR2. Rumors have been flying in both directions. If they do go with DDR2 it won't be until lower latency higher speed DDR2 becomes the norm and it shows increased performance over DDR1. Which until you OC the stuff to outlandish speeds, that doesn't happen.
For overclocking DDR2 is great, but the latencies suck. most of the stuff runs at CAS 3 or in most cases 4, which is way worse than CAS 2 DDR1 memory. The Athlon specifically gets plenty of memory bandwidth with an integrated memory controller, and do better with lower latencies rather than more bandwidth. Which makes DDR 2 an unwise choice at this time. Even if you could do it.
