I've tried two different 2x1GB kits in my P5K-VM and none of them work at DDR2-800 even if I push the voltage all the way up to 2.1V. I either get memtest failures or BSODs. The kits I have tried are the OCZ 2G8002GK (rated @ 2.1V) and 2P800R22GK (rated @ 1.9-2.1V). Again I have tried pushing the voltage on both, all the way up to 2.1V which is the max on the P5K-VM, and even relaxing the timings to 5-5-5-15. If I run them at DDR2-667, everything works perfectly.
Does anyone know if there is a 2x1GB DDR2-800 kit that will definitely work on this board?
