For my upcoming C2D build, I'm planning on running at 3.0GHz. I know that with the 9x multiplier on the E6600 setting the FSB at 333MHz, DDR2-667 would be running at a 1:1 ratio.
Since I'm not planning on tweaking the RAM at all, would Corsair Valueselect PC2-5300 be acceptable? Is there any reason NOT to save a couple bucks and get this stuff? As I understand it, with the XMS2 and Dominator series, you're essentially paying for tighter timings and more overhead which I'm not really going to use (I think).
http://www.newegg.com/product/product.asp?item=N82E16820145098 is the set I'm looking at.
From what I gather, lower timings have a minimal impact on performance with Intel chips. I'm not a hardcore enthusiast by any means, I don't mind a mild OC, but stability is my main concern.
I also am looking at these g.skill sticks (http://www.newegg.com/product/product.asp?item=N82E16820231098) but I'm not sure about running the RAM and cpu at a non-1:1 ratio. Does that make much of a difference?
