I am about to upgrade to a Intel E8500 on Monday having already upgraded my Video card to a 512 8800GTS so I will be getting a Motherboard, CPU and Ram. Now the Motherboard I am getting is a Gigabyte X48-DQ6 motherboard shown here:
http://www.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ProductID=2763
According to the Motherboards Specs it supports up to DDR2 1200 Ram (I am guessing looking at the chipset that it will support DDRIII with a bios update but not out of the box?)
Here is the Supported Memory list for the GA-X48-DQ6 :
http://www.giga-byte.com/FileList/MemorySupport/motherboard_memory_ga-x48-dq6.pdf
The problem is my local store only sells Selected Memory i.e DDR2 800, DDR2 1066 and DDR3 1333 since this is the case my best bet is to go with DDR2 1066? On the Supported Memory Page it says it supports 1066 ram and then it says in brackets 'Overclock to DDR2 1200'. Now what does this exactly mean? Does it mean I have to Overclock it to DDR2 1200 speeds or is it done automatically by the motherboard? Does this mean it won't boot with DDR2 1066 Ram installed at stock speeds?
If so how do I overclock the Memory out of the box using the Bios? I have overclocked and upgraded a few times but I have never touched the memory speeds before so sorry if I sould a bit noob !
I am really looking forward to getting my new upgrade up and running, after a windows reinstall of course! I can go and get DDR2 1200 memory if it is too much of a pain in the butt but that will involve a bit of a drive and I am getting the Motherboard and CPU at a store nearby!
Please help!
Thanks !
Please help!
Thanks !
