ddr standard mean the maximum?
PC3200=DDR400=200MHz stock clock...DDR standing for Dual Data Rate, or double normal SDRAM, processing on the rise and fall of the clock cycle. This refers to the minimum that will be required to support the processors native FSB. PC3200 is, AFAIK (don't quote me) is the last approved DDR1 spec for JEDEC, so that's the one that everyone uses for their boxes. That DFI can probably go up to 300MHz from 200 in 1MHz increments. DFI is good stuff. I went with ASUS A8R32-MVP Deluxe, based on same Xpress 3200 chipset, saved $40.
if you want to run the ram in Dual Channel mode can you only do that with 2 sticks?
Like I have 4x 512 mb sticks. Do I have to get 2x 1 gb sticks to make dual channel work?
This simply refers to the way that the motherboard is setup. most modern machines are setup for Channel A and Channel B (in reference to RAM banks). Channel A typically consists of Slots 1 & 3, Channel B being slots 2 & 4. DDR1 for desktops is 64-bit. Dual channel (or putting one stick of RAM in each of the two channels) opens up the memory interface to utilize 64-bit x2 for the data path, or 128-bit memory interface for system RAM. All you need to enable Dual Channel is 2 sticks...if you have 4, then all the better. However, keep in mind that with most Athlon64 based CPU's, 4 RAM sticks require you to run at a command rate of 2T, instead of 1T. The performance difference between 1T and 2T is something like 3%, so it's not detrimental. Hope this all helps!
Thanks alot bud that helped quite a bit .
But one thing I would like to know is, what is the highest speed these boards can do? Do i have to stay with 3200 speed? or Can I get the new faster speeds?
The DFI board for certain goes up to 300MHz on the FSB. You can run your RAm on a divider, so that it stays close to the 200MHz rated stock speed (although it will likely be stable higher than 200). What will determine your OC will be the CPU's capability to run an oc'd FSB, and the RAM (if not run on a divider to keep it at or below 200). OC'ing is a lot of trial and error. I make an excel spreadsheet of my voltages, FSB, multiplier, and FSB, and HTT link speed whenever I am OC'ing, so I know what I've already tried.
So that's the long answer. The short answer is yes, most likely you can run your RAM over 200MHz (stock 3200 speed), but it's not garaunteed. It depends on the stability of each individual module, the more modules you have, the more points of possible failure you are introducing into the equation. It's the lowest common denominator factor.
as sabregen said afaik the highest jedec standard for DDR is 3200 so that's the highest that any manufacturer will officially support.
Certainly in the case of abit boards running the same CPUs/chipsets you can actually use faster memory so I would expect the DFI to be the same.
