DDR and DDR3? Do i need it?
shiek
Hey guys,
First post and im looking towards purchasing a new Video Card. I was either contemplating between two chipsets x800XL or 6800GT, both 256mb.
Now what i realized is that the cards that have "DDR3" are about 200 dollars (CAD) more than the ones that dont have it. My question is; what is the difference. Can you guys give me some links with statistics on this type of memory?
thank you very much
The cards that have GDD3 are priced much higher because it is one of the many features included on these higher end cards, its not only the better memory that'd raising the price that much. Like everyone else said, GDD3 is clocked much higher.
So basically what im asking also; is it worth getting DDR3 on my video card? I do game a lot.
That's like saying is it worth getting $2000 turbocharger on my car. What car are you buying? If you're getting a viper, I'd say sure, if you're getting a honda, I'd say there's no point (not that they'd even offer it, which is the case here). No graphics card comes to mind that strictly offers both DDR and DDR3. Maybe it's bigger brother does (6800GT over a 6800 for instance), but that's because the faster card can utilize the faster memory. There's no point sticking fast memory on a slow card, because it cant use the bandwidth because the GPU isn't fast enough.
depends. Memory interface size is much more important than whether or not the ram is DDR of DDR3. the 6800 has DDR memory and a 256-bit wide bus which will absolutely rape a 6600GT with a 128-bit bus and DDR3 mem.
Exactly - don't compare them based on DDR vs. DDR3. DDR3 isn't really a 'feature', it's just a way of reaching higher memory clocks.
