Hello, I've been trying to set up DDNS for days now. I got it to the point where I could resolve hosts but I had the error "Unable to add forward map" but then started getting "ns.domain.ca: temporary name server failure" and DNS would not work at all.
Below at logs and configs;
syslog:
Jan 22 09:50:12 delle6430 named[2920]: zone 127.in-addr.arpa/IN: loaded serial 1
Jan 22 09:50:12 delle6430 named[2920]: zone domain.ca/IN: NS 'ns.domain.ca' has no address records (A or AAAA)
Jan 22 09:50:12 delle6430 named[2920]: zone domain.ca/IN: not loaded due to errors.
Jan 22 09:50:12 delle6430 named[2920]: zone 0.168.192.in-addr.arpa/IN: loaded serial 6
Jan 22 09:50:12 delle6430 named[2920]: zone 255.in-addr.arpa/IN: loaded serial 1
Jan 22 09:50:12 delle6430 named[2920]: zone localhost/IN: loaded serial 2
Jan 22 09:50:12 delle6430 named[2920]: all zones loaded
Jan 22 09:50:12 delle6430 named[2920]: running
Jan 22 09:50:13 delle6430 named[2920]: managed-keys-zone: Key 20326 for zone . acceptance timer complete: key now trusted
Jan 22 09:50:13 delle6430 named[2920]: resolver priming query complete
Jan 22 09:50:32 delle6430 named[2920]: message repeated 2 times: [ resolver priming query complete]
Jan 22 09:50:36 delle6430 dhcpd[2860]: DHCPREQUEST for 192.168.0.121 from mac (host1) via eno1
Jan 22 09:50:36 delle6430 dhcpd[2860]: ns.domain.ca: temporary name server failure
Jan 22 09:50:36 delle6430 dhcpd[2860]: DHCPACK on 192.168.0.121 to mac (host1) via eno1
Jan 22 09:50:36 delle6430 dhcpd[2860]: DDNS: cleaning up lease pointer for a cancel cb=0x55fd8ab603b0
Jan 22 09:50:36 delle6430 dhcpd[2860]: Unable to add forward map from host1.domain.ca to 192.168.0.121: operation canceled
Jan 22 09:50:43 delle6430 kernel: [ 5243.753758] [UFW BLOCK] IN=eno1 OUT= MAC=mac SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
Jan 22 10:56:48 delle6430 dhcpd[2860]: DHCPREQUEST for 192.168.0.111 from mac (android-1) via eno1
Jan 22 10:56:49 delle6430 dhcpd[2860]: ns.domain.ca: temporary name server failure
Jan 22 10:56:49 delle6430 dhcpd[2860]: DHCPACK on 192.168.0.111 to mac (android-1) via eno1
Jan 22 10:56:49 delle6430 dhcpd[2860]: DDNS: cleaning up lease pointer for a cancel cb=0x55fd8ab65150
Jan 22 10:56:49 delle6430 dhcpd[2860]: Unable to add forward map from android-1.domain.ca to 192.168.0.111: operation canceled
zone links:
:~$ sudo ls -l /var/cache/bind/
total 8
lrwxrwxrwx 1 root root 28 Jan 21 13:49 db.192.168.0 -> /etc/bind/zones/db.192.168.0
lrwxrwxrwx 1 root root 31 Jan 22 06:51 db.domain.ca -> /etc/bind/zones/db.domain.ca
-rw-r--r-- 1 bind bind 821 Jan 22 08:28 managed-keys.bind
-rw-r--r-- 1 bind bind 512 Jan 22 08:28 managed-keys.bind.jnl
/etc/bind/named.conf.local:
include "/etc/bind/ddns.key";
zone "domain.ca" {
type master;
notify no;
file "/var/cache/bind/db.domain.ca"; # zone file path
allow-query { 192.168.0.0/24; 127.0.0.1; };
allow-update { key DDNS_UPDATE; };
zone "0.168.192.in-addr.arpa" {
type master;
notify no;
file "/var/cache/bind/db.192.168.0"; # 192.168.0.0 subnet
$TTL 604800
@ IN SOA domain.ca. root.domain.ca. (
6 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
604800 ) ; Negative Cache TTL
@ IN NS ns.domain.ca.
ns IN A 192.168.0.106
$TTL 604800
6 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
106 IN PTR ns.domain.ca.
/etc/dhcp/dhcpd.conf
authoritative;
option domain-name "domain.ca";
option domain-name-servers ns.domain.ca;
ddns-updates on;
ddns-update-style interim;
ignore client-updates;
update-static-leases on;
default-lease-time 600;
max-lease-time 7200;
log-facility local7;
include "/etc/dhcp/ddns.key";
zone domain.ca. {
primary 127.0.0.1;
key DDNS_UPDATE;
zone 0.168.192.in-addr.arpa. {
primary 127.0.0.1;
key DDNS_UPDATE;
subnet 192.168.0.0 netmask 255.255.255.0 {
range 192.168.0.110 192.168.0.210;
option routers 192.168.0.1;
50-cloud-init.yaml:
network:
version: 2
renderer: networkd
ethernets:
eno1:
addresses: [192.168.0.106/24]
dhcp4: no
gateway4: 192.168.0.1
nameservers:
addresses: [192.168.0.106]
00-private-nameservers.yaml:
network:
version: 2
ethernets:
eno1: # private network interface
nameservers:
addresses:
- 192.168.0.106 # private IP for DNS
search: [ domain.ca ] # DNS zone
syslog:
zone links:
total 8
zone "domain.ca" {
type master;
notify no;
type master;
notify no;
$TTL 604800
6 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
$TTL 604800
6 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
authoritative;
ddns-updates on;
zone domain.ca. {
primary 127.0.0.1;
key DDNS_UPDATE;
primary 127.0.0.1;
key DDNS_UPDATE;
50-cloud-init.yaml:
network:
version: 2
renderer: networkd
ethernets:
eno1:
dhcp4: no
nameservers:
network:
version: 2
ethernets:
nameservers:
addresses:
