DDC pump top, screw dimensions
Ultragamma
Hi all, i am trying to make the acrylic top for the ddc pump, and i am looking for the dimension of the 4 mounting screw holds. Anyone know how far are they from adjacent center to center? if you have a pump on hand that will be great, i hate to flush my coolant out and just for the measure. Thanks in advance. I already finish most of it, now just need the 4 mounting screw holes, i will post pictures later.
if your talking the metal base on the bottom, which connects the base to the computer thats 1 inch 21/32, but thats only 2 holes...
i assume you mean...
if your talking about the 4 screws that hold the pump, onto that metal base, those seem to be 2 inches exactly on center.
hope that helps.
Chris
that is what i wanted, 4 screws holding the pump top to the bottom motor part. so it is 2inch apart exactly? Thanks so much!! will post some pictures once i get home from work
