*Insert sexual orientation joke here
* I am doing a new build using one of these pumps from dangerden and due to EXTREME space limitations (see my worklog
) I may need to install the pump "on its side." Installing the radiator in the position I have it does not leave enough space on the bottom of the case for the pump. If I raise the radiator up, then there will be a gap in the side panel below it, it will not be blowing directly on the components I want it to, and more of the air it is pushing will be obstructed by the 5 1/4" drive bracket.
You can see what I'm talking about best in this picture
In the above picture, the right side is the front of the case, and is where I would horizontally mount the pump. I assume that it is best to mount it with the inlet on top, however I don't know if mounting it in this position effects the noise or vibration of the pump, not to mention performance. Any insight would be helpful.
