DDC-2TPMP mounting (NOT 56K friendly)!
  • Thread starter Deleted member 134350
  • Start date
D
Guest
This new feature from Mountain Mods where they attach brackets to any 120mm fan to hold three hard drives works perfect for holding the modded pump in front of my case fan. I have a Yate Loon running at full volts blowing air directly at the back of the pump where I installed some heat sinks to help cool the pump motor. The fill-port in the res is just for bleeding and will be removed when finished (it is the delrin model from DD).
I still have some wire management in the background to take care of so please just ignore it. :D
