scottatwittenberg
- Apr 10, 2002
so i flashed a wrt54g with dd-wrt today and connected it to my wireless network and created a bridge.
dhcp does not work through this bridge however. I had to set a manual ip for my computer that's connected to it.
any idea where i may have messed up, or does it just not work for some weird reason.
more info.
main router is an ISP provided cable modem - wireless linksys router WCG200 v.2
64bit wep key on channel 10
linksys wrt54g v4 with i flashed it with this file:
Mini-Build required for inital flashing via WEB dd-wrt.v24_mini_generic.bin 2008-07-27 2,77 MB
main router is 10.10.10.1
dd-wrt router is 10.10.10.2
set the same wep info on the dd-wrt, and named it the same as the other one.
went to status -> wireless -> site survey -> found my AP and clicked join.
it connected and i could get to my other computers, but not the internet. so i tried 10.10.10.1 for DNS and still couldn't. So then I put in my ISP dns info and was fine.
I restarted the dd-wrt router and then my computer wouldn't renew the ip, so i set it manually.
and that's where i am at. it works fine. but i would like dhcp to work through it if possible.
Thanks
more info.
Thanks
