DD tower case
Hey I am considering getting the tower or case that the Big-) uses for Origin PC that's right the huge one. Would it be worth it and what would I be able to fit into the case. It is huge like a box except is it 26 inches tall. Would you recommend it. I really like the look of it and if anyone does have one please tell me about it. It looks beast to me and it could fit like 4 way sli.
http://www.dangerden.com/store/dd-double-wide-tower-21-black-series-edition.html#tabs
if the case isn't good than can you recommend me to a good case that can fit some really high tech components. Thanks
What do you think because I am planning on building a 700 dollar rig and would that cas be good for it.
Plus please tell me how hard it is to build your own pc. This is my first time and I really want a 6950 is that enough to max out current games. What would you say about the rig though. It is the same as the Big-O from Origin PC. I want to recreate that. All help is appreciated.
Well if that is the look you are looking for you will have to buy that one but it is kind of expensive if all you have is 700 bauckaroos for the computer.
As for building a computer, Its very simple things can only fit in one place.
6950 is powerful but I don't know what resolution you are playing on.
I will be playing on 900p or 1080p. Both. How many gpus would I need when I do have more money to spend ao that I can get 3 monitors. I heard it is a beast experience. And I would just like to know what do you pefer amd or nvidia. Which would you go for a gtx 560 or 6950. Which is better
if you want 3 monitors save a little and grab a 6970. You can go crossfire later.
