Is anyone happy with their DD/Swifty new poly reservoirs? I just removed mine from my system and Im not too impressed with its design. I think the top water fillport goes way to far down into the reservoir (its actually goes below the waterline) which makes it hard to get air out and actually allows water to seep through. I also think they need to move it from directly behind the input lines and behind the output side so it would cut down on the water seeping through the fill cap. Ill post some images of what im talking about in a bit.
*edit* here are some pics of what I am talking about...
pic1 here is the front view into the res and youll see how far down the fill port goes (circled blue) and see how the inlines to the res will go directly into the fill port...
Here is the inline side view (blue line is how low th fill port is)...
Here is the output side of the res which is a bit lower than the inline side so it wont pass air which unfortunatly still happens (blue line is how fill port depth)..
