- Jul 5, 2007
So I just learned the hard way that Danger Den's "Summit" waterblock for Radeon HD 5850 and 5870 doesn't fit on Diamond's 5850. (Diamond model no. 5850PE51G.)
The waterblock collides with the capacitors circled in cyan, and even if that weren't the case, I'm not sure the waterblock would reach over the caps and inductors circled in yellow.
A warning to all y'all looking to buy and watercool a 5850....
So can anyone recommend a waterblock that will fit?
