SevenWords
- Sep 8, 2006
Hi, I'm thinking about getting a Danger Den RBX but I had a question about the two outlet nozzles on it. With a strong enough pump (I believe mine is a DD D-4) can you send one outlet to the gpu block and one to like a NB block and then use a Y fitting to bring them back to one just before the res? I wasn't sure how this would affect flow or performance, or if it would even work. Sorry, I'm just beginning in WC.
