DD MC-TDX Intel 775
no it doesnt... the mounting system is terrible for those blocks (even though the block performs good i will say that)
if you get one the best thing to do is glue the bottom nut to the bolt that goes underneath the motherboard otherwise you'll be tightening it one day and it will fall off behind the motherboard.
LOL . . .I always do that. Also, use a brass knurled head screw right on top of the washer next to them mobo on the top part instead of a regular screw. That way you can tighten it easily (they come loose as well).
I have several backplates from Danger Den . . .you can get one custom if you call and ask for Debbi.
LOL . . .I always do that. Also, use a brass knurled head screw right on top of the washer next to them mobo on the top part instead of a regular screw. That way you can tighten it easily (they come loose as well). .
haha i knew i couldnt be the only one... nice idea adding the brass head screw on the top side of the board too i will remember that for the next DD build :D
do you think i would need one??
if you're one of those people who likes to tighten things down really hard to the board then i suggest getting one to avoid bowing the board, if you just tighten it till its tight and not like stressing tight then you wont need one.
well i have left debbi a message hopefully i will get a call back today i think i may just go ahead and get it only because i have 18 reward points with them and i think i should just use them =) i will let you know what happens thanks for all the help
