DD Maze4 GPU installation / temps help
trajik78
hey, the install instructions @ DD's website on how to properly tighten the nuts on the maze 4 aren't really pertinent to the 6800 so i was curious how much i should tighten them?
also, my GPU is @ 47c idle/50c load - 420/1.11, seem about right?
MCW6002-P
DD Maze4
D4 pump
BIX2 w/ 2 Panaflo M1A's
If you can see the PCB actually twisting and contorting because of the screws you've gone a little too far, so back it off a little like 1 and a half turns and that should be good. Those temps look okay for the OC.
