go away trollR1ckCa1n said:It takes time to copy other designs and release them.![]()
bladeiai said:it would be cool if they did something to keep the card from snaping of the pci-e slot under the weight of all that copper like the nv68
Erasmus354 said:As for people copying others designs.... The nv68 came out before the AC 6800 block... OMG WTF HAX0RZ!!!!1111oneoneone they copied AC before they even released the block!!!![]()
Top Nurse said:Sorry, but you are incorrect. Perhaps you are thinking about the revision 2 AC block? All the AC blocks have a very common design and they have been making this design for quite a while (i.e. ATi 9800, Nvidia 5900). Sorry you lose![]()
ROFLMAO - show me an original idea that came from that camp.Vertigo Acid said:go away troll
their 7800 is just a re-tooling of the 6800 block they already have, changed for the different RAM height
R1ckCa1n said:ROFLMAO - show me an original idea that came from that camp.
The 7800 block is way different since it must also cool the mosfets.
If you only knew young jedi.........Erasmus354 said:How about showing us something they definitively copied from someone else? As was said earlier, stop being a useless troll.
R1ckCa1n said:The 7800 block is way different since it must also cool the mosfets.
Again, no, you're wrongdangerden.com said:There is a change to the 7800 series cards. The height difference of the RAM to the GPU has changed by about the diameter of a human hair (0.006 inches or 0.15mm). Danger Den will make a modifed block to officially work with the 7800 series. Also, there is RAM on the backside of the card. This requires a modifed backing plate and RAM sinks.
Don't get your panties in a wadVertigo Acid said:Again, no, you're wrong
Before you try to discuss about products you so obviously know nothing about, please go do some research or something to pull your head out of your ass.
I may not agree with AC's school of thought on water cooling, but that doesn't mean I talk down about them as if I knew a thing about them, which I don't.
Erasmus354 said:The stock mosfet heatsinks will be more than adequate for overclocking. Unless you want to do some uber leet overclocking, but in that case you will be getting Viper John to professional modify your card for higher voltages and what not.
Top Nurse said:Now how would you know that? I see your "new computer" sig shows a 6600 class card.![]()
A perfect reason to buy the DD block then?ryuji said:is that why my 6800gt at 1.4v had its mosfet sink get literaly burning hot and thats with the rad fans blowing on it so it wasnt completely dead air... had to add cooling to my fets added benefit was cool memory which = higher clock
ryuji said:the dd block DOESNT cool the mosfets, memory cooling is useless, just a little air flow over the stock 6800 gt heat sinks on one side of the heat pipe made the sinks practically room temp
its like water cooling system memory, its just plain silly unless your feeding them 3v in a volt mod or somthing, and in that case you wouldnt be a noob and use the dd water block youd use some nice heat sinks and at least pelt a normal water block, or phase change it
absolutly no reason to run any of the total card cooling mechanisms, i get cooler temps on my 6800 with the prescott feeding it heat then you guys get on your athlon-64 water loops and the nv68, and thats a insult considering you paid twice as much for less performance
Yes that is why the mosfet heatsink on my 7800GTX is hot to the touch as is the ram. There is a reason companies make the waterblock to cover all of the components that actually get hot.Erasmus354 said:That means the mosfet sinks are doing their job. Unless you are having power stability problems with the card then you know that everything is working just fine. Also the 7800GTX consumes less power and puts out less heat than the 6800, so if you had no stability problems with your overvolted (?) 6800 then a 7800 should be just fine. If the 7800 really needed more than just mosfet sinks then you wouldn't be seeing such highly clocked retail cards on air cooling.
Strapped for cash are we?mikelz85 said:I feel the watercooled ram solution blocks are stupid. You're far better off saving the money for something better.
Cooling or not cooling the RAM will have absolutely nothing to do with how high your clocks go on the GPU.....mikelz85 said:I know, I for one, will be hitting much higher clocks than anyone with a RAM cooled solution, as even though the maze 4-1 GPU doesn't cool the ram, it does sport a 40mm peltier, which keeps everything pretty cool. I look forward to using it on my new 7800GTX, which is coming refurbed via newegg for $420.
R1ckCa1n said:Strapped for cash are we?
Cooling or not cooling the RAM will have absolutely nothing to do with how high your clocks go on the GPU.....![]()
R1ckCa1n said:Yes that is why the mosfet heatsink on my 7800GTX is hot to the touch as is the ram. There is a reason companies make the waterblock to cover all of the components that actually get hot.
ryuji said:my card was unstable until i added cooling to the mosfets, invalidating you guys whole discussion, and about the gtx, it actualy consumes slightly more power then the 6800 ultra, nvidia was bragging about performance/watt not total power consumption compared to older cards
my card is only running at 1.4v(6800 ultra) and my prescott runs at 1.55v, yet a cpu hot enough to run at 60C load doesnt heat the water more then 0.5C? is that why when i had my northwood 2.8b in there i got 38C load on my gpu compared to 46C load?
water doesnt heat up, adding second fan to my double heater core made sure of thatErasmus354 said:Yes the processor only heats the water about 0.5C from waterblock inlet to waterblock outlet. I am assuming that your water is flowing around 2lpm (low to moderate flow) and that your prescott is dumping out 100W of heat (just cause its a nice even number). If your temperature goes up so much then it tells you a very nice thing about your watercooling loop, you are lacking in the radiator department. You will likely see a large improvement by getting a larger radiator, or adding a second one.
