- Mar 30, 2005
Are heatsinks that big safe for your CPU/MB if you move it around? My case doesnt leave my desk often but when it doesnt i really dont want to have to take off my heatsink.
I have installed many very heavy heat sinks (with pelt chips) and have not seen or had any problems with moving them as long as they are secure and you don't set the system down hard to create a bounce effect.Are heatsinks that big safe for your CPU/MB if you move it around? My case doesnt leave my desk often but when it doesnt i really dont want to have to take off my heatsink.
I just had one do that in Vista 64.I just had it happen again on another core. It went to 99% and then, after 5 minutes, went to 100% where it sat for 10 minutes before going back to 1%. During all of this, I watched the core utilization and it never dropped below 99%.. just continued crunching so it definitely did not restart. Just very odd progress meter behavior like Andy states I guess. Again, this is Linux, so maybe it's even more exaggerated than it is on Windows.
Currently have 6 sitting at 70% with the longest running unit at 35H 37M and the shortest at 31H 45M. I haven't completed one yet. I left 8 running while I slept last night but just paused two of them to free up some memory to hopefully let these 70% units run a little more easy.I just had one do that in Vista 64.
Did yours continue on back to 100% and complete?
Ok. Please let me know if the one you had restart, restarts again if you know which one that was.Currently have 6 sitting at 70% with the longest running unit at 35H 37M and the shortest at 31H 45M. I haven't completed one yet. I left 8 running while I slept last night but just paused two of them to free up some memory to hopefully let these 70% units run a little more easy.
All of them here have "restarted" once according to the progress bar. However, I don't believe it was a true restart meaning the work actually restarted from the beginning. I think it's just part of the overall progress bar bug that plagues this garli application. I have no evidence whatsoever that there was a true restart with any of these projects here.Ok. Please let me know if the one you had restart, restarts again if you know which one that was.
We've seen this happen before, albeit recently. There are known problems with the progress bar, but it shouldn't ever go backwards like that. Perhaps rebuilding GARLI against the latest BOINC API will help- I'll try to do that soon.
Epic fail on that, WTF people?The last is in quorum with a Power Macintosh Model PowerBook6,7 with 512mb memory.![]()
You get points when you turn in either one.Has anyone figured out these Wieferich@Home Wus yet? It seems as though its doing 2 WUs at a time? It looks like one WU finishes pretty quickly and the other one takes quite a bit longer. And I take it your score doesnt update until you submit of the bigger WUs?![]()
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
22392 jt 39 19 19312 4272 2052 R 100 0.1 4:32.70 dnetc
22799 jt 39 19 19312 2312 92 R 100 0.0 4:03.29 dnetc
21745 jt 39 19 1049m 712m 1544 R 100 12.1 36:29.74 garli_5.15_i686
21746 jt 39 19 1049m 710m 1548 R 100 12.1 36:26.04 garli_5.15_i686
21747 jt 39 19 1049m 713m 1548 R 100 12.1 36:27.49 garli_5.15_i686
21743 jt 39 19 1049m 706m 1548 R 98 12.0 36:25.77 garli_5.15_i686
21744 jt 39 19 1049m 710m 1544 R 98 12.1 36:26.35 garli_5.15_i686
22798 jt 39 19 19308 2312 92 R 96 0.0 4:03.95 dnetc
Razor_FX_II is the first to have credit granted to the Lattice project. We are finally on the board!![]()
http://boinc.umiacs.umd.edu/team_display.php?teamid=1187
You can download it from here: ftp://ftp.distributed.net/pub/dcti/prerelease/betaRazor - Any chance that you are using the Linux RC5-72 Cuda Client? I want to reformat the machine that I have running RC5 to 64 bit linux but I dont have the old CUDA client downloaded. So if I did a reformat I would lose the ability to run that client.Thought maybe if you were running the Linux version you could send it to me.
I've sent in a request to the PSP administrator to create a [H]ard|OCP team. I'm now working on some sieve's that count for both PSP and SoB so we should also start seeing some SoB-Sieve numbers soon.
Edit: I believe this is the one you will want: dnetc508b2-linux-amd64-cuda-elf.tar.gz
I noticed we lost a spot in Wieferich@Home thanks to Alliance Francophone. This project is going to be tough. I'll keep two cores devoted to it, but I think easier points might be found elsewhere.
I feel your pain I just completed a unit that had a quorum with 10 people that had client error.I was out of town for the weekend and just got back. I see one of my Lattice Project work units finished, but I got no credit. The claimed credit was 570.89 points for 26.5 hours of CPU time, but 9 other results failed and one is still pending, so the entire work unit has the error "Too many total results" (11 with 10 max). Hopefully the people that can't run these WUs will figure it out and remove themselves from the project.
I'm working on a second unit now (15 hours so far) and have a third in the queue. The good news is that the WU I'm doing now already has a successful result, so I should get the points immediately when I'm done. It should finish in a few hours. The third unit looks like it might have a second successful result as well.
Ditto. Mine was 826.82 claimed and I'm going to get 0. I also have another one in progress that no one else was able to complete. I've turned in 7 units so far, only 1 has been granted credit to date. The other 5 still pending will hopefully be granted soon. I still have 7 WUs still crunching. I'm currently devoting 5 cores at a time to Lattice until I buy some more "D".I feel your pain I just completed a unit that had a quorum with 10 people that had client error. That one was 642.05 claimed credit.![]()
Excellent, they also have a new native 64-bit Windows beta client. I was getting worried as my current 64-bit beta was getting set to expire in a couple days. The 64-bit beta supports both RC5-72 and OGR-NG.There is a new distributed.net x86 CUDA client v2.9103.509 (beta)
I've got 2 more cores I can switch on..... what project do you want then to work on?
I'm currently hammering ABC, and I'm also working on rosetta and Einstine. I also have one core working on a mutant uber huge climate change WU.
Hey Kendrak - Have you joined the [H]ard|OCP team for ABC@home? I dont see you on the stats page.
What a slacker, reason #24 I did not vote for him.Kendrak is teamlesss in ABC.![]()
