ABC is having server issues tonight and SIMAP is giving out work again, so I switched to SIMAP for the few days of work it will have then I'll go back to ABC for about 400k in points (about a month).Razor - Are you going to stay on ABC for a while?
Sounds like a good plan - maybe I can catch up to you in ABC. My 2700K cranks ABC work units out fast.Gotcha. I'll stick on Docking for the rest of the week (Docking has scheduled downtime for the 9th) and then switch over to ABC this weekend and join you for an ABC run. Maybe we can gain some ground.
I tried running Docking for a few weeks and found that on my Intel CPU's it had issues but on my one and only AMD CPU it ran fine, so I switched until they get that issue fixed.
Max OC was 5Ghz prime stable but temps on most projects are to hot for my comfort - 70C+, so I set it at 4.6Ghz and run average temps of 55-60C which also keeps my voltages in what I consider the safe zone since there is no clear max volt for these CPUs and I don't want to degrade the chip.I bet it does! How fast did you get your 2700K running? I have never used a Sandy Bridge chip before but i was surprised how easy the overclocking went on my 2500K. I didn't want to push it too far for DC'ing but i felt like 4.2 was decent.
phoenicis - What CPU project did you end up choosing to work on?
Nice. That would be a nice jump! Speaking of a nice jump I see we jumped another spot in Majestic12 today. Props to Razor and McCoy for their continued work over there!I'm helping out on PSP. With any luck we should be able to snag 4th place and 357 Vault points within a month or so.
Truly outstanding work on Poem and Cosmology guys. Also particularly commendable are the chaps still slogging away at yoyo weeks after the contest finished - they must be having fun.
Nice going everyone!
Good to hear man! Thanks for keeping the [H]ard|OCP ORG-27 team on an upward trend!Still - or again - working on OGR-27. Team HardOCP will be at Top 50 in a few days![]()
Agreed! Looks like you guys will be up to 60th place in another week. Not bad for being in about 120th place a month ago!Great work on Cosmology everyone!![]()
Welcome to the ABC team KMac! Good to have you along. I dont think it will take us long to hit the top 100! Maybe a week or so. My production has been steadily climbing but I'm guessing that it will start level off here now that I have all my machines switched over. Crunch ON!I am going to help get us at least into the top 100 for ABC.
A weekend with no FreeDC is giving me stats withdrawal.![]()
Its killing me as well. I keep going on my BOINC screen to see where we stand on certain projects. I need my FIX ASAP![]()
I'm a little torn on this one - personally I don't like the project application or how it keeps score but on the other hand I hate to see all the [H]ard work SazanEyes and the rest of the Commandos have put in to it go for nothing.There is some discussion over on whether to remove Wieferich@Home.
http://www.team-ninja.com/vbulletin/showthread.php?t=50705
He has been the lone wolf in that project for a while and is keeping us on the level.Likewise with TheTMZ in ORG.
# apt-get update
# apt-get upgrade –y
# apt-get install boinc-client
# nano /etc/boinc-client/cc_config.xml
# boinccmd --project_attach http://docking.cis.udel.edu xxxxxxxxxxxxxxxxxxxxxx
# boinccmd --project http://docking.cis.udel.edu update
# boinccmd --set_run_mode always
# boinccmd --set_network_mode always
# boinccmd --project http://docking.cis.udel.edu resume
# /etc/init.d/boinc-client stop
# /etc/init.d/boinc-client start
# boinccmd --get_simple_gui_info
# boinccmd --get_state
# boinccmd --join_acct_mgr http://boincstats.boincstats.com/bam name password
Congrats to the PSP Combined guys, another place gained and another 357 points!!!
phoney - Thanks for the link.![]()
SoB
To Join the Project:
Go to their website www.seventeenorbust.com and click on the “Sign Up” link on the left side. Create a Username and enter your email address. Login to the site with your new username and select the preferences link to add your name to the [H]ard|OCP team.
To Run the Project:
Go to the link Download on the left hand side and get the proper version of the client software. Also download the Prime.txt file and put it in the directory for SoB. Extract the folder and Run “prime95.exe” Make sure you add your username to the Primenet under Test. Other than that just let the client run and your all set the WUs are pretty long though.
sudo apt-get install ia32-libs libstdc++6 freeglut3
sudo apt-get install boinc-client
sudo /etc/init.d/boinc-client restart
boinccmd --project_attach URL auth
boinccmd --project URL detach
phoney -- Nice guide on the hp cloud service but I can write it faster(from the BOINC wiki) I had to learn how to do it for my ubuntu server last year. (Can't have equipment not crunching you know)?
phoenicis / SazanEyes -- Are you sticking with PSP for the forseeable future?
