Gilthanis
[H]ard|DCer of the Year - 2014
- Jan 29, 2006
I can switch a few GPU's over to Asteroids to try to help out.
And they supposedly have Maxwell support.
WCG needs to do something about it quick or they may get a bad rep in the DC community. That is what I would want to do is run my rigs so somebody else would want to hack my account and profit from my expense.
We have found that a few of our members have unexpectedly had their team choice changed to the "Ripple Labs" team. After investigating this, we can confirm that there was no break-in to World Community Grid and users' devices were in no way compromised.
We have identified a computer that was trying combinations of user names and common passwords against our website in an attempt to find combinations that worked. This activity began on March 11, 2014 and successfully guessed the passwords of a few of our volunteers. It appears that users whose passwords were guessed had their account's team choice changed to the "Ripple Labs" team but were otherwise left unmodified. Within 36 hours of the attack, this computer was blocked. We have been monitoring our systems closely for similar attempts. We will notify all members who joined the Ripple Lab team since this began and ask them to confirm their intention to be on that team.
We take security very seriously and follow industry best practices to best protect our users. We will continue to use best practices to block such password-guessing attempts. We will also conduct a complete review of other aspects of account and password management and determine what, if any, additional changes should be made there.
We are sorry to see that this happened to a few of our members. To avoid this kind of problem in the future, we strongly advise all users to adopt the best practice of selecting passwords that are not trivial or common. Avoid using short passwords and those containing simple words, obvious number, letter or keyboard sequences. You can see examples of weak passwords that should be avoided here: http://boingboing.net/2013/12/07/worst-passwords.html. We also advise that you avoid using the same password across multiple sites.
More pogs optimized programs for Linux, compiled in ubuntu 13.10 on opteron 6234 and i7 M620 with intel fortran... 90m wu and 60m wu respectively.
https://dl.dropboxusercontent.com/u/123993183/fit_sed_x64_linux.tar.gz
unzip to home, and copy to pogs project directory while renaming the file to overwrite theirs.
On my system the boinc client and project directory is ....
sudo cp ~/fit_sed_x86_64-pc-linux-gnu_340_intel /var/lib/boinc-client/projects/pogs.theskynet.org_pogs/fit_sed_x86_64-pc-linux-gnu_340
and then the next wu that starts will copy it into the slot and run the new version...
If you restart the boinc client it will overwrite the file unless you add an app_info.xml in the project directory also...
14247771 6781461 16 Feb 2014, 12:18:04 UTC 16 Feb 2014, 21:07:23 UTC Completed and validated 6,701.70 6,701.70 168.15 fitsedwrapper v3.40
14058212 6690455 14 Feb 2014, 19:25:17 UTC 15 Feb 2014, 2:36:14 UTC Completed and validated 7,522.29 7,447.81 185.85 fitsedwrapper v3.40
14032102 6677539 14 Feb 2014, 13:44:08 UTC 14 Feb 2014, 19:25:15 UTC Completed and validated 7,085.17 7,035.31 177.00 fitsedwrapper v3.40
13926562 6627892 13 Feb 2014, 10:35:49 UTC 13 Feb 2014, 18:06:00 UTC Completed and validated 5,657.18 5,629.04 141.60 fitsedwrapper v3.40
13813051 6572225 11 Feb 2014, 22:40:05 UTC 12 Feb 2014, 6:12:38 UTC Completed and validated 7,892.68 7,809.88 194.70 fitsedwrapper v3.40
16537474 7851862 15 Mar 2014, 10:05:42 UTC 15 Mar 2014, 11:27:39 UTC Completed and validated 1,964.20 1,943.72 168.15 fitsedwrapper v3.40
16537466 7851858 15 Mar 2014, 10:05:41 UTC 15 Mar 2014, 11:27:39 UTC Completed and validated 2,170.98 2,141.00 185.85 fitsedwrapper v3.40
16535548 7850905 15 Mar 2014, 9:28:43 UTC 15 Mar 2014, 10:38:03 UTC Completed and validated 2,105.87 2,080.25 177.00 fitsedwrapper v3.40
16523282 7844870 15 Mar 2014, 5:17:49 UTC 15 Mar 2014, 6:34:56 UTC Completed and validated 1,627.92 1,609.03 141.60 fitsedwrapper v3.40
16530844 7848631 15 Mar 2014, 7:59:17 UTC 15 Mar 2014, 8:45:38 UTC Completed and validated 2,249.70 2,224.25 194.70 fitsedwrapper v3.40
16530728 7848573 15 Mar 2014, 7:59:17 UTC 15 Mar 2014, 9:28:42 UTC Completed and validated 2,461.43 2,431.94 212.40 fitsedwrapper v3.40
Most of the optimizations is being done by the intel fortran compiler (60%gain on the old code) and combo of my changes then increased it to 220% gain. But they would have get the proper license for the intel compiler, (it is free on linux and personal, non-commercial/non-academic use)
When I tried the changes on the gfortran compiler it was only a 20% gain... so next would be to change the code more so gfortran optimizes similar to the intel version. I have been playing with the c++ port for openCL version instead...
