DC++ Help
Funky_Junk
I have just started using DC++ and I think I might be having trouble. I have high speed internet, but whenever I download a file I usually only get speeds around 10 KB/s. Im not sure if these are normal speeds or if it should be going faster. I am using a router but I dont think that is a problem because I opened the port (1412). Is this a problem on my end or is it a problem on the other persons computer? Thanks.
Most non-business internet connections are asymmetric, which means that the upstream bandwidth is smaller than the downstream bandwidth. My Comcast cable, for example, is 4Mbit/s downstream with 384kbit/s upstream. If I were to send a file to someone else, it would be transmitted at 384kbit/s (48kiB/s) at most.
From my limited knowledge about DC, it seems that some hubs require people to have multiple 'slots' open, so that three or four people would share those 48KiB/s. Add in some overhead an 10kiB/s is actually a pretty nice rate to download at.
DC++ has a rediculous amount of overhead. Also keep in mind that several ISPs (Rogers in particular) throttle P2P traffic like mad.
Regards,
Former Rogers Customer
