- May 18, 1997
Please only post your Horde graphic once per thread.
I'm confused...... how can we make this work?
No problem. It's one of the reasons I avoided the new larger sig's which seem to consume more bandwidth and take longer to load.
I like the look of the new badges a lot, but can see what you are saying.
I will be switching back myself.
Edit:
Kyle, if you are still checking this thread, I would like to propose a suggestion. I don't know if this would be more work than you would like, or maybe more bitching from other board members than you might like, but what if after a certain number of points (say 1 million because I just got there) you could put those folders in a member group that has the rights to post HTML in their sigs. It's just a suggestion, and would make it so we would have more than one per thread if we posted several times, but if it is the older smaller one that might be ok right?
Just a suggestion.
Edit:
Just a suggestion.
OopsI'm sorry if I scewed up. Does this mean if you post several times to the same thread you should just use your badges one time
I wonder if this issue has been resolved yet .. or what was causing it in the first place?
Is it the new code vs the old code?
Is it the new [H]ardForum and [H]ardOCP servers?
Just curious what changed from the old sigs to the new to hurt the servers.
I don't like to ever get Kyle upset around here....
How do you insert this tag? I had one back in the day, when you could permanently attach it to your sig.
