Hi all
I am looking to build a media PC for the living room. I have run into a couple of questions regarding parts and OS choices. This PC will not be used for heavy gaming, it will be burning DVD's, playing movies, doing a lot of TIVO work, surfing and email, and some limited office type duties. Will be priced around $1200 CDN (my spending limit).
Requirments:
Must be as quiet as possible.
Must be as small as possible (considering parts being used)
Must be stable (24x7)
Parts being thought about (with alternatives in brackets):
AMD Athlon XP 2500 Barton (maybe mobile?)
ATI Radeon 9600 All in Wonder (maybe XT version?)
Maxtor 120 GB Quiet Version (good choice?)
512 MB PC3200 DDR
NEC Dual Layer DVD Burner
Parts I have absoulutely no idea which way to go:
Case: Small Form Factor or Antec Sonata?
MB: Obviously a mATX for SFF - would like to use an NForce2 chipset for the audio (Soundstorm) - I am really open to suggestions here (except I will be using and AMD proc.)
OS:
Windows XP Pro or Media Edition? (I will be using an MS product)
If anyone has any previous experience building a set up like the one I'm looking for, let me know.
If anyone has any suggestions for parts, let me know.
If anyone has any good links, let me know.
I was looking at the Antec Aria for a case, but it looks like it has some heat issues, and I will not be modding the case choosen at all. My main PC is a Sonata, and I like how quiet it is, but it may be too big for the living room.
Thanks in advance.
Requirments:
512 MB PC3200 DDR
OS:
Thanks in advance.
