so_cal_forever
- Jan 5, 2004
Is there anyone who has teh 100w Dayton subwoofer that could snap a pic of the back (amplifier) for me? I'd like to see if it has binding posts for speakers such as this sub has:
Mister X said:That means it has exactly what you are asking about....
You connect the speaker output from your amp/receiver to the high level inputs on the sub and then connect the speakers to the high level output.
The sub takes the high level input reduces it to a line level signal, sums it, filters it, amplifies it and then feeds it to the driver in the cabinet.
Can you see why you would want to avoid connecting it like this?
JTY said:Some receivers don't have a sub out, or a line level output that could be used.
Isn't that a given?so_cal_forever said:So you're still partial to connecting the sub to the tape inputs?
so_cal_forever said:That would just involve buying a good subwoofer cable, correct?
What crap?What is all that crap?
Can you show me a single active sub in your price range that doesn't have a adjustable crossover?so_cal_forever said:It was suggested earlier that I use the tape inputs given I was using a sub with an adjustable crossover frequency, but I'd just like to hear more info on this.
Mister X said:Can you show me a single active sub in your price range that doesn't have a adjustable crossover?
I can't find one... of course I didn't look very hard either.
The new SVS PB10-ISD has no crossover to speak of, as it only has one connection (an RCA input) on the back.
You will get better results by using the speaker-level input/output connections.
GodsMadClown said:It's good to have the high pass filter (crossover) uptream of the speakers. This way they only get signal that they are most effective at reproducing, and the woofers will have less distortion than if they were asked to play the whole frequency range.
GodsMadClown said:You will get better results by using the speaker-level input/output connections.
GodsMadClown said:It goes something like this...
Receiver/Amplifier -> speaker wire -> subwoofer speaker level input -> High-pass filter/crossover -> subwoofer speaker level output -> speaker wire -> speaker.
This way, the speakers get the frequencies above the crossover setting. The speaker will have better power handling and less distortion on the woofer cone.
