Dave's Short List
My latest update, your input is requested.
Thank you,
Dave
Updated 3-5-07
Dave's Short PSU List
webstien said:
I had to make this
attachment.php
As you will see all PSU's recommended for highend systems are Single +12V Rail PSU's.
This has now become necessary for several reasons:
PSU manufactures are now assigning the rails on their multi-rail (3 or more +12V rails) PSU's in whatever fashion pleases them.
Motherboard manufacturers are now requiring additional power connectors, beyond the standard ATX & P4/EPS connectors.
Sometimes the interaction of these unique rail assignments & additional power connectors results in mobo/PSU incompatibility.
All of these problems are of course caused by the ever higher power demands of ever more powerful GPU's.
Most Dual +12V Rail PSU's are not effected as one rail "should always" be used exclusively to power the CPU via the P4/EPS connector, however Dual Rail PSU's that follow the specs can not power highend SLI systems.
Therefore all PSU's recommended for highend systems now need to be Single +12V Rail PSU's.
Please note that the Seasonic built Corsairs & Antecs (HE & Trio) are, regardless of advertising,
Single +12V Rail PSU's, in that there is no per-rail current limiting, meaning that any +12V rail can pull whatever +12V amperage is available. This is also true of the Seasonic M-12's.
The Corsairs are built to higher standards than the Antecs.
From PC P&C's Power Supply Myths Exposed!: http://www.pcpower.com/technology/myths/
8. ARE MULTIPLE 12-VOLT RAILS BETTER THAN A SINGLE 12-VOLT RAIL?
With all the hype about multiple 12-volt rails (ads claim that two rails is better than one, five is better than four, etc.), you’d think it was a better design. Unfortunately, it’s not!
Here are the facts: A large, single 12-volt rail (without a 240VA limit) can transfer 100% of the 12-volt output from the PSU to the computer, while a multi-rail 12-volt design has distribution losses of up to 30% of the power supply’s rating. Those losses occur because power literally gets “trapped” on under-utilized rails. For example, if the 12-volt rail that powers the CPU is rated for 17 amps and the CPU only uses 7A, the remaining 10A is unusable, since it is isolated from the rest of the system.
Since the maximum current from any one 12-volt rail of a multiple-rail PSU is limited to 20 amps (240VA / 12 volts = 20 amps), PCs with high-performance components that draw over 20 amps from the same rail are subject to over-current shutdowns. With power requirements for multiple processors and graphics cards continuing to grow, the multiple-rail design, with its 240VA limit per rail, is basically obsolete.
PC Power and Cooling is once again leading the industry. All of our power supplies now feature a large, single 12-volt rail. The design is favored by major processor and graphics companies, complies with EPS12V specs (the 240VA limit is not a requirement) and is approved by all major safety agencies such as UL and TUV.
From Silverstone: http://www.silverstonetek.com/products-da750.htm
"With the knowledge that single +12V rail power is the next generation power supply, SilverStone Technology introduces Decathlon series, offering enthusiasts more choices with single rail power selections to handle their system."
PC P&C Turbo-Cool 1KW-SR [Single +12V Rail] (+12V@72A) (The Best of the Best of the Best!)
Specs: http://www.pcpower.com/products/viewproduct.php?show=T1KWSR&view=techspecs
$499: http://www.pcpower.com/products/viewproduct.php?show=T1KWSR&view=about
SILVERSTONE Olympia OP1000 1000W [Single +12V Rail]
Up to +12V@80A
Specs: http://www.silverstonetek.com/products-op1000.htm
From: $335: http://froogle.google.com/froogle?q=Silverstone+OP1000&btnG=Search&lmode=online&scoring=p
Zippy PSL 6850P 850W [Single +12V Rail] (+12V@60A)
Specs: http://www.zippy.com.tw/P_PRODUCT_D...1358&pp_code=PSL-6850P&pcp_rfnbr=3&lv_rfnbr=2
Gaming Specs: http://www.zippy.com/P_product_deta...pw_rfnbr=6&pp_code=Gaming?PSL-6850P(G1)-PCIE4
From $322: http://froogle.google.com/froogle?s...C:en&q=Zippy+PSL+6850P&lmode=online&scoring=p
PC P&C Silencer 750W [Single +12V Rail] (My #1 Choice for Uber SLI/CF with any current GPU's!)
Up to +12V@60A
Specs: http://www.pcpower.com/products/viewproduct.php?show=S75QB&view=techspecs
$199: http://www.pcpower.com/products/viewproduct.php?show=S75QB
Silverstone Decathlon DA750 750W [Single +12V Rail]
Up to +12V@60A
Specs: http://www.silverstonetek.com/products-da750.htm
From $178: http://froogle.google.com/froogle?s...on+DA750&oe=UTF-8&um=1&lmode=online&scoring=p
SilverStone Olympia OP750 750W [Single +12V Rail]
Up to +12V@60A
Specs: http://www.silverstonetek.com/products-op750.htm
From $149: http://froogle.google.com/froogle?q=Silverstone+OP750&btnG=Search&lmode=online&scoring=p
SeaSonic M12 SS-700HM 700W [Performs as a Single +12V Rail PSU.]
Up to +12V@56A
Specs: http://www.seasonicusa.com/m12.htm
From $189: http://froogle.google.com/froogle?s...M+ATX12V&oe=UTF-8&um=1&lmode=online&scoring=p
Corsair HX 620W [Performs as a Single +12V Rail PSU.] (My #1 Choice for Highend SLI/CF!)
Up to +12V@50A, +5VSB@3A
Specs: http://www.corsairmemory.com/corsair/HX_power_supply.html
From $129: http://froogle.google.com/froogle?s...C:en&q=Corsair+HX+620W&lmode=online&scoring=p
Can the Corsair 620HX Power Supply Handle 8800 GTX SLI: http://www.legitreviews.com/article/462/1/
I have personally tested this PSU & I highly recommend it for highend systems with all current video cards.
SilverStone Olympia OP650 650W [Single +12V Rail]
Up to +12V@54A
Specs: http://www.silverstonetek.com/products-op650.htm
Fron $127: http://froogle.google.com/froogle?q=Silverstone+OP650&btnG=Search&lmode=online&scoring=p
Antec TruePower Trio 650W [Performs as a Single +12V Rail PSU.]
Up to +12V@52A
Specs: http://www.antec.com/specs/TP3_650_spe.html
From $103: http://froogle.google.com/froogle?q=Antec+TruePower+Trio+650W&btnG=Search&lmode=online&scoring=r
Silverstone Zeus ST56ZF 560W [Single +12V Rail] (+12V@38A)
Specs: http://www.silverstonetek.com/products-56zf.htm
From $115: http://froogle.google.com/froogle?s...6ZF+560W&oe=UTF-8&um=1&lmode=online&scoring=p
Corsair HX 520W [Performs as a Single +12V Rail PSU.] (My #1 Choice for everything else!)
Up to +12V@40A, +5VSB@3A
From $97: http://froogle.google.com/froogle?q=Corsair+HX+520W&btnG=Search&lmode=online&scoring=p
I have personally tested this PSU & I highly recommend it for highend systems with any single video card.
Antec Neo HE 550W [Performs as a Single +12V Rail PSU.]
Up to +12V@42A
Specs: http://www.antec.com/specs/NeoHE550_spe.html
From $89: http://froogle.google.com/froogle?q=Antec+NeoHE+550&btnG=Search&lmode=online&scoring=p
Antec TruePower Trio 550W [Performs as a Single +12V Rail PSU.]
Up to +12V@42A
Specs: http://www.antec.com/specs/TP3_550_spe.html
From $80: http://froogle.google.com/froogle?q=Antec+TruePower+Trio+550W&btnG=Search&lmode=online&scoring=r
Antec Neo HE 500W [Performs as a Single +12V Rail PSU.]
Up to +12V@38A
Specs: http://www.antec.com/specs/NeoHE500_spe.html
From $74: http://froogle.google.com/froogle?q=Antec+Neo+HE+500W&btnG=Search&lmode=online&scoring=p
Sunbeam NUUO 550W [Dual +12V Rails] (Max Combined +12V@30A)
Specs: http://www.sunbeamtech.com/PRODUCTS/Power-supply/NUUO/nuuo-550.htm
$70: xpcgear jab-tech svc
VANTEC ION 2 VAN-460N ATX12V/ EPS12V 460W[/B] [Single +12V Rail] (Perfect for Older (+5V CPU) Systems)
Output +3.3V@28A; +5V@30A; -5V@0.5A; +12V@30A; -12V@0.8A; +5VSB@3.0A
Specs: http://www.vantecusa.com/p_ion2460.html
From $60: http://froogle.google.com/froogle?s...=VANTEC+ION+2+VAN-460N&lmode=online&scoring=p
This is my #1 Recommendation for older PC's where the CPU is powered by the +5V rail.
XCLIO GOODPOWER 500W[Dual +12V Rails](Best Bang for the Buck!)
Specs: http://www.xclio.com/htm/products-PSU-Goodpower500w.htm
$52: http://www.newegg.com/Product/Product.asp?Item=N82E16817189005
I have personally tested this PSU & I highly recommend it for mid-range systems.
Enhance ENP-5150GH 500W [Dual +12V Rails]
Specs: http://www.enhanceusa.com/series.php?series_id=4#115
From $67: http://froogle.google.com/froogle?s...0GH+500W&oe=UTF-8&um=1&lmode=online&scoring=p
If the XCilo GoodPower 500W is not available, this is a good alternative for midrange systems.
XClio 450BL ATX 450W [Dual +12V Rails] (Best Bang for the Buck!)
Specs: http://www.xclio.com/htm/products-PSU-450BL.htm
$38: http://www.newegg.com/Product/Product.asp?Item=N82E16817189003
Review: http://www.extremeoverclocking.com/reviews/cases/Meridian_XClio_450W_1.html
I have personally tested this PSU & I highly recommend it for low to mid-range systems.
Enhance ENP-5140GH 400W [Dual +12V Rails]
Specs: http://www.enhanceusa.com/series.php?series_id=4#43
From $54: http://froogle.google.com/froogle?q=Enhance+ENP-5140GH&hl=en&btnG=Search&lmode=online&scoring=p
If the XCilo 450W is not available, this is a good alternative for low to mid-range systems.
FSP Group (Fortron Source) BoosterX 3, 300W SLI Graphic Power Supply
Dedicated Multi-GPU Graphic Power Supply Unit
Specs: http://www.fspgroupusa.com/FSPNEWS/BOOSTERX3.asp
From $66: http://froogle.google.com/froogle?s...+3,+300W&oe=UTF-8&um=1&lmode=online&scoring=p
If you have a good PSU, but need more power for SLI,
just put this +12V (only) GPU PSU in an empty 5.25" bay!
Jason's (EOC) Reviews: http://www.extremeoverclocking.com/articles.php#13
jonnyGURU's Reviews: http://www.jonnyguru.com/reviews.php
Legit Reviews: http://www.legitreviews.com/articles/power_supply/
Nvidia SLI Certified: http://www.slizone.com/object/slizone_build_psu.html#certified_powersupplies
For more information: http://forums.extremeoverclocking.com/showthread.php?t=136602&page=1&pp=20
Updated 3-5-07
Thank you,
Dave ;)
I suggest the addition of the Sunbeam NUUO 550. Tested well, works great for me (My rig puts 150w load on it, so at least I know it's good to 150w ;) ). Only problem is Fuhjyyu, but given proper ventilation, it should be good. Same goes for the XClio 450.
What about the Silverstone ST56ZF, ST75ZF, and ST85ZF? The 75 and 85 are multi railed, but for 99% of people it's not an issue. The 56 has a shit ton of power, and like the 75 and 85, are etasis built goodness.
Thank you for the input. ;)
EDIT:
The Sunbeam NUUO 550 has a max combined of only +12V@30A & they want $90 for it!
$90: http://froogle.google.com/froogle?s...UUO+550W&oe=UTF-8&um=1&lmode=online&scoring=p
"All the power of a XCilo 450W/500W at twice the price!"
Is there some place to het this for under $60?
EDIT:
As per your suggestion the Silverstone Silverstone ST56ZF 560W has been added.
Thanks again,
Dave
thanks dave i have been looking for something like this to use in othe4r forums if you dont mind
