Data Transfer Speeds over eSATA
capreppy
[H]ard|DCer of the Month - April 2009
The laptop in sig (Asus G71V-Q1) has an eSATA port. I've got a couple of external drives that I take with me on the road.
I have a 320GB 7200RPM WD Scorpio Drive in a Vantec NexStar 3 Enclosure.
The HDDs in the laptop are the same as the one in the enclosure.
I also have a Seagate Barracude 7200.11 1.5GB 720 RPM in a Thermaltake 3.5" External Enclosure.
When transferring data, I never get more than 6 to 10 MB / second transfer rates. There are times when I need to transfer data to someone else's drive and I get up to 20MB / second transfer rates.
I normally transfer larger (700MB+) files. Should I expect higher transfer rates? Is there anything I can do to increase transfer speeds?
eSATA will have the same speed as internal SATA. Something must be screwed up with your drives, cabling, or enclosure.
What are the major factors that would affect overall transfer speed?
CPU Usage
DIsk Usage (if I'm torrenting to the drive or a VM is on the drive and active)
Memory Usage
Ok. I tried looking up DMA and PIO. I'm not knowledgeable enough to figure this out.
Where should I be looking at to figure this out. I tried google, but got a lot of info on Windows 2000 and XP, but frankly not a whole lot of info on Vista
