Data Structure
PadanFain
C - System and small applications
now here is my question
Have about 25 gig in music
I also download a lot. Sometimes huge linux dvds, ect
My D is a 5400 40 gig
and my E is 120 gig 7200
Should I use the smaller, slower D for the music and the faster E for the games/downloads or
downloads on the slower drive and the music on the faster drive with the games
Any input?
I would do this ^^.
consider your optical drive is far far slower than either HDD
it has no problems serving up the music
however you might consider seperating the OS from the P2P
P2P by its very nature is small, nearly constant accesses
and will fragment the hell out of a partition, and likely lag the OS as well if its on the same drive
whereas the music might be a kinder access pattern to share with the OS
at least you can guarantee the music files arent fragmented ;)
review > http://www.hardforum.com/showthread.php?s=&threadid=741512
OS and programs should go on faster drives. Movies and Music should go on slower drives.
