Data recovery software
EnderW
My friend called me yesterday and said somehow deleted all the pictures on his external hard drive. The drive itself works great and everything else is still on there. I told him I would take a look at it, but I've never done this before. Ideas?
Any undelete utility will work just fine, just make sure he didn't put any more files as it can really overwrite the deleted files. Google "free undelete utility" or something like that.
Edit: there is also another utility just in case the image file (most likely jpeg) is corrupted, but usually are not free.
I have used GetDataBack for NTFS V3.32 and am EXTREMELY HAPPY with its performance.
There are previous versions around on the net which are FREE although this one isn't. It works like a charm though.
I second GetDataBack.
