Data Recovery Plz Help!!!!!
caje005
i accidentally reformated my hard drive not realizing that i still had CRUCIAL data still on the drive. What is the BEST data recovery program out there to get it back? Its windows XP home in NTFS. THANKS
File Scanvenger will do that but will you need a place to recover the data to. Hopefully you haven't tried to use the drive since you reformatted. If so you are basically screwed.
http://www.quetek.com/prod02.htm
It is well worth the price.
