Data Recovery, my disk is dead(ish). help!
Cylinder
I have a WDC2500JB 250GB Caviar that has been running about 4 1/2 years. It suddenly stopped booting.
At first it said no drive attached. Then it said some windows file was missing & to use the XP cd to repair.
I didn't notice any clicking noise or anything like that. But. the computer did arbitrarily reboot a couple times in the days prior.
Now I have some files on there I want to save that were encrypted using Windows.
If i pull them off using another drive (w/ the dying/dead one as a slave drive), will I be able to unencrypt those files? How?
Should I try to pull files off using another drive before I attempt to do any work to repair that drive? (like running SpinRite)
I've heard that putting the drive in the freezer for a day helps. Will this help or just do more damage?
Thanks!
I had this same issue a few weeks ago. I will give you the same advice I was given, retrieve the data first and then try to trouble shoot the drive. I used GetDataBack and it worked beautifully to retrieve my "lost" data.
using your windows disc boot to recovering mode
do a chkdsk /r
this will check and repair your disc if any errors are found.
Once its done see if you can boot to windows and retrieve/backup any data.
If chkdsk doesn't work your gonna have to look into some recovery software like
GDB, easy recovery,
Putting your drive in the freezer can help it work a little better. Some people have found that it gives them just enough time to get the data off it before it warms back up again.
Personally, I would try to access the drive as little as possible until you've got all your data off. Booting off a CD (BartPE or something) combined with the freezer trick may allow you to pretty easily get all your needed data off the drive. If the data is actually corrupted, you may need to do a chkdsk (or more), but I'd first see how much data you can retrieve from the drive before making any changes to it.
If it doesn't seem like a physical issue with the drive itself, you might also be able to repair it with a controller board swap off an identical drive. Obviously this will only work if the problem is in the board rather than the drive itself.
I'd try the freezer trick and then slap spinrite on a disk and give it a go.
Btw. the freezer trick only helps with initializing the drive. The drive heat up pretty quickly after that.
The only problem w/ pulling the data off w/o copying it from windows is most of it was encrypted using windows encryption & i never got around to backing up the encryption key. So unless there's some way i could crack the encryption after recovering it outside of windows getting the data will be fruitless. :(
There's about 500MB of encrypted data I'm trying to save, the rest of the drive i can consider a loss.
do a chkdsk /r
GDB, easy recovery,
Will this overwrite/change the windows encryption key like re-installing windows? How long would it take on a 250GB drive where about 150GB is used & 100GB free?
From other threads I've been reading it seems like it helped some people boot back into windows which is what I really need to do if I can't crack the window's encryption somehow.
Thanks to all you who are helping! :)
