Hey guys, my previous thread talking about my blown PSU which I discovered later it took out my hard drive with it. Here is my last post:
RAM tested with MemTest+, 2 passes, no errors.
Windows Check disk on functioning hard drives, no errors.
Ran Geoforms on graphics card, no strange behavior
Ran prime95 and othos for about 30mins, no errors.
Now, the broken hard drive:
Specs: Western Digital Caviar Green WD10EADS 1TB 32MB Cache SATA (link)
All recovery programs I've looked at so far keep thinking the hard drive is about 33.4MB large, with a Cylinders-Heads-Sectors of 64-16-63. In reality its 1TB.
GetDataBack seemed to do the best, recognized the actual size of the drive:
Step 1
Start: Cyl 0 Head 1 Sector 1
End: Cyl 1023 Head 254 Sector 63
LBA start: 63
Total sectors: 1,953,520,002
Bootable: No
Step 1/During scan
Many:
I/O Error 'Unknown error (65284)' reading sector XXXX on HD129.
until I choose 'Yes to all'
Index Allocs: 66
Boot sectors: 1
Files identified: 2 starts, 0 usrdef
MFT entries: 0,0 $MFT
Step 2 - Select File System
http://img715.imageshack.us/img715/2539/step2c.png
Step3 - Recovery Tree
No files listed....
testdisk did the 2nd best, it was able to recognize the hard drive was 1TB big. Although says it can't recover the partition.
Spinrite noticed the different sizes/partition of the drive. Wasn't able to run recovery on the drive, even after all its warnings that I shouldn't
Ultimate Boot CD didn't seem to want to load any of its programs... Although, Ultimate Boot CD for Windows' utilities worked.
Western Digital's WinDlg was only able to scan the 33.4MB limited space. The quick and extended test, and SMART all return no errors.
HDTune only recognizes 33.4MB, no errors, health OK, able to read temperature.
and so forth.
Scenario 1
The hard drive is still in its 3 year warranty period. Although I have never RMA'd a hard drive before, I don't know the extent of their fixing abilities. Maybe they could replace the chip? The platters itself should be ok...
or
Scenario 2
I could format the hard drive, then try to recover data again, while hoping for the best....
or
Scenario 3
Use testdisk to manually set the 'geometry' (Cylinder-Heads-Sectors) of the drive, although I don't know them. May foobar things more?
or something else!
Step 1
LBA start: 63
Bootable: No
Step 1/During scan
Many:
Index Allocs: 66
Boot sectors: 1
No files listed....
and so forth.
Scenario 1
or
Scenario 2
or
Scenario 3
or something else!
