On my D drive (250 gig 7200 RPM 8mb cache WD running off abit IDE > serial converter on Abit NF7-S Revision 2 - athlon xp 3200 not overclocked) files/folders started to get corrupt, so first thing i di dwas backup as many files as i could (most)
then i tried doing the disk check with the WD software (on ultimate boot disk) and it wouldn't start the test.... then i thought maybe the serial converter was bad - so i replaced it with an extra one i have lieing around, then bam the test went 100% fine and most of the files/folders that windows claimed to be corrupt were uncorrupt and life was good
this was 3 days ago and tonight it started happening again... i did the WD utility again and it says the drive is fine....
Any clues what I should do?
By the way the reason it's on the serial converter is all my IDE slots are full...
2 optical drives, 4 hard drives - 1 a real serail HD and the other (the one this thread is about) the WD
the thing that irks me is the same setup has been running 100% fine for the last 5 months...
