My first post to this forum, but I really need advice and I've already tried elsewhere, so here goes:
I was messing around with an app meant to get my A64 to throttle down, and it did something weird with my multiplier so I had to go back into the BIOS to reset it correctly. In the process I accidentally disabled my RAID controller (yes, I know, I'm a retard), and when I turned it back on the info for my partition was gone. I tried creating a new RAID 0 partition with the same properties as the old one and without erasing any of the information on the drives, but my controller wouldn't let me specifiy the new partition as bootable and I could never get past the screen where Windows asks whether you want safe mode or normal mode. On the fifth or sixth run-through I did something even more retarded: I accidentally told my controller to clear the data on the drives. Needless to say, my compy no longer boots at all. If I can get these drives hooked up to another computer with a SATA RAID controller, is there some way that I can put the stripes back together into coherent files and save my data without the original MBR (which I assume is now lost)? Maybe there's some software out there capable of doing that?
