terayon1515
- Mar 23, 2006
Hey All,
I have a Dell PERC 5/i RAID card I purchased off eBay with a BBU. It is running in my Norco 4020 on an Intel-based Asus board (listed in my sig) - I had to block the SMBus pin on the card in order to have it function on this board.
I am experiencing extreme data corruption across the array. I have eight WD 500GB's (WD5000AAKS) drives connected to the controller. Everything was fine when the array was initially set up, tested it out and everything was gold. A few weeks later I experienced a HDD failure, the array was still accessible, so was the data.
When I inserted a replacement drive and rebuilt the array - 50% of all data was corrupted, still there, but totally garbled. (I use it for housing large MKV's) - I started the arduous task of replacing the bad files, and everything has been fine for months. I chalked it up to me hotswapping the drive in my Norco 4020 (which has a bit of an issue hotswapping with its backplanes)
BUT, last night I had another drive fail, replaced it (by powering down the machine, and cold-swapping) - rebuilt, and I'm hit with the same amount, if not more of garbled MKV's and data corruption. Moreover the file folder that keeps this data was reported as 'Corrupt and Unusable" by Windows Server 2008 - After I ran a 'chkdsk /f /r /v' the folder became accessible, but the files within are mostly garbage now.
The BBU is healthy and (checking the logs) has been cycled and tested. I am running a 'consistency check' from the MegaRAID manager right now, ETA 2hrs - but I haven't seen anything pop up in the logs, so that could be useless.
Does anyone have any good experience with these PERC 5/i cards? I had read on here of many users who like the cards. I can no longer use the card for any purpose as any drive failure will result in massive loss of most files (indiscriminately)
Can anyone help me with this? I would be forever grateful!
Happy holidays!
Happy holidays!
