Data CD Burning
asyork
I was working on some homework today when I realized that I have never burned a data CD from my Mac. I need to put a Power Point presentation onto a CD for one of my classes, and I have no idea how to do it. I was just looking around, and found nothing that looked like it would do what I needed. Does OSX come with any software that allows you to create and burn a data CD? If not, is there any reliable freeware that will get the job done? Thanks in advance.
Not 100% sure but I belive you can just drag and drop the files onto the cd in finder and it will start some burning process.
Scratch that. I had it set up to ignore a blank disc... Now I can see the burn button. Thanks for your help.
