Does anyone here have a DasKeyboard yet? How do you like it?
Hence why I want to spray paint my keyboard..UltimaParadox said:80 dollars is pretty ridiculous
Borgschulze said:Hence why I want to spray paint my keyboard..![]()
Oh you do, you just don't realize it...compslckr said:i dont really look down that much anyways.
qdemn7 said:Das Keyboard the KB with NOTHING on any of the keys. Works with Windows, OS X, and Linux. Only $79.95 shipped. The two good things about this KB are the fact it has premium keyswitches, and different levels of key wieght depending on where the keys are located. As for me, maybe I should buy one and learn to touch type after 35 years instead of having to look at the keys.![]()
mikeblas said:I already type fast; between 100 and 110 words per minute. This keyboard says it can double my speed; even if it gives only a fifty percent improvement, typing 150 wpm would be worthwhile!
FunkStar said:Dude its all a gimmick.
I know I would like that feature, sounds nice as I always miss some keys with my pinky because my keyboard takes too much force to press down on those keys.mikeblas said:So you didn't find the variety of spring rates helpful?
