Das Fridge
JavaJiver
Okay...
I have an old mini fridge sitting around. I've pondered a few projects but think I have settled on the one go with.
I'm going to set up the entire fridge to function as a radiator.
The plan is...
Used coolant comes in through a port in the bottom on the fridge. It enters the reservoir. From here it is pumped into a radiator. From this the liquid passes into a smaller radiator through smaller tubing (to increase pressure) this smaller radiator is located in the freezer compartment of the fridge. From there it heads out of the fridge and into the pc.
I figure it this way.
The coolant comes into the refrigerator and is cooled upon reintroduction in the reservoir.
The coolant is cooled further as it passes through the radiator.
The coolant is brought to near freezing temps as it moves through the final radiator.
The coolant is then pushed through the system....
What do we think?
Questions or suggestions before I begin?
you may need some sort of insulation or waterproofing to prevent condensation on the tubing from coming into contact with your comp. just a thought :)
