DarthBeavis Projectlog: Order 66 Redux
DarthBeavis
I needed a rig for the BYOC at NVision 2008 and did not want to bring the Skully again . . .so I thought I would rebuild Order 66 to celebrate the new Star Wars movie . . .
I decided to competely gut the Alienware ALX chassis and rebuild it ala the new VooDoo (IO facing up).
Here is a shot of the old Order 66 if you guys had not seen it:
First mod after replacing all the interior hardware was having a window cut:
Company who did the window used it in their ad:
At Smooth in 2006:
Case painted after:
Early upgrades:
Outside:
Another revision:
Thermaltake block cracked:
So another upgrade:
and more:
and more:
Anyways, it has been rebuilt many times . . .started out at an ALienware ALX AMD FX55 with SLI 6800 Ultras ;)
Current stuff:
Here is is gutted out (cut out the HDD and optical bays, PSU support and mobo tray):
Next I hope to get to Danger Den to get them to make new inner panels out of UV blue arcylic. I will cut the front and back panels out leaving only a frame so I can attach the outside painted panels. I have a nice SMooth Creations painted PA 120.3 for it already and will use a Bonetrail 2 board and my old QX9650 . . .
Subscribed, can't wait to see this. And you can tell you had some major leakage in that last shot.
Yep subscribed as well, anything to do with star wars will get my attention...apart from Hayden Blackman, his excuses are the worst I have heard for the lack of a PC version of The Force Unleashed *uses force choke on Blackman*.
