Darn molex connector
CarpCharacin
My motherboard is an asrock x99 fatal1ty micro ATX and it has a PCIE molex power connector at the bottom and I can't seem to get it in. I was thinking about using pliers, but I don't want to damage it. Molex connectors are a pain. Any ideas on how to get it in?
Grab it with pliers and shove it in, wrap tape around the pliers or use plastic coated if your concerned about damage.
With your index finger and thumb, grab the bundle of wires at where they meet the molex plug.
Wiggle left and right to the sides while gently pushing upwards.
4-pin Molex connectors need to die a swift death. I have always hated them. Having to wiggle the cables and/or pop them back into the connector grinds my gears. :mad:
I just saw this thread too. come on man, we cant walk you through every step of your build. next youll be in the Linux forum asking how to install that!?
its fine! your system is built fine. now youre coming across as a troll, knock it off! and for the love of the [H]Gods DO NOT try and put Linux on this, you clearly do not have enough experience. load windows, load newest drivers, load some games and start enjoying you system, FFS!
CarpCharacin You do know you only need to plug a molex connector in to that plug if you use more than 3 video cards.
Didn't you read the manual before you starting installing hardware?
I applaud your sincerity. Either that or your sarcasm, whichever that was.
Either way, the standoff is totally cool. The only serious thing you can mess up standoff wise is flexing the board due to an uneven height of one or more standoff. And the other danger is stripping the motherboard's protective layer around the screw hole.
I just hope the standoff hole isn't stripped. I could have probably built my computer without asking any questions here, but I worry about stuff a lot.
