Danner Mag *PondMaster*
Proven
Wow, this thing is HUGE. Compared to a L30 it is twice the width. I bought it and am going to see if it will fit in my case. You guys rave about it, so I got it. Anyone else got one of these in their Lian-li mid tower with the hd-cage in place?
I hope this thing is more quiet compared to the L30. you think the Danner would improve my cooling?
Mine won't fit in my antec unless I ditch my soundcard or rip out my hdd bay. It's the main reason I haven't installed my w/c system yet.
thinking about making a bracket for the pump to mount facing down from the top of my case. kinda sux but o wellz.
that was my concern as well, I have a audigy in my computer and it is a tight fit with the L30. Hmmmm....How to make it fit!
Does it have to fit inside the case? You could build a very small external unit to hold the WC components, or just the pump (well damped against vibrations).
Yup that's what I did. I built a boc for WC components. You better have a lot of tubing tho.
Yes I really prefer it to be mounted inside the case. It's no big deal, it will fit. It just won't drop right in without some ingenuity. But it's all about the challenge right?
I prefer mine in my case as well. It just makes me feel better. I can fit it in there. It is just tight. Once I flipped the intake and made it more up and down, It fit a little better. How it came, it was too wide. All the pictures on the net make that thing look half its size.
