Dangerden Maze installation?
ttoad4000t
Hey,, I just bought a new AMD Dangerden kit, and in the manual the says to insert the screws in the "cpu mounting holes surrounding your cpu socket" Now, I have never seen holes surrounding any cpu, nor is it on my motherboard. Am I reading this wrong, or have I always just had motherboards without these?
You should have four mouting holes around your socket. If you don't have these... well.... you'll need a socket hold down device.
Some motherboards have the 4 mounting holes around the cpu socket and some do not. Unfortunately you ordered the wrong mounting kit. You'll need to order the Socket Tab Hold Down to mount your Maze4.
