Kill?? What are you talking about? Unless you're working on it with the thing plugged in or while juggling knives at the same time, I don't think you have to worry about that.alexyang said:I'm aware that working on a guitar amplifier is pretty dangerous and can easily kill, but what about making a headphone amp? Is it still dangerous or is it much safer?
dotZIP said:I was under the impression that you only made high end stuff![]()
alexyang said:f I have absolutely no experience in soldering whatsoever, and I don't YET have a lot of "fine building" skills, how hard is it to build a Cmoy?
Since we are all speculating while he could post his own reply and have it be 100% sure I am going to say he used to build them but no longer does.Deadlierchair said:Oh he builds them all I think.
zachary80 said:Since we are all speculating while he could post his own reply and have it be 100% sure I am going to say he used to build them but no longer does.
Talonz said:Asking Mister X to build a CMOY is like asking a F1 mechanic to change the oil on your Ford Pinto![]()
jerb said:the capacitors (caps) are the things that can hurt/kill. there is no use for caps big enough to hurt you in a portable amp so there shouldnt be too much danger. maby a small shock if you short out the board ( dont be proding when its on)
i doubt that the charge that small, moving that far would have any effect, besides it would probbably go down through your legs (earth ground) rather than to the other hand. i wouldnt try it though, it only takes .6 amps acrost your chest to kill you (dont try it, it will stop your heart)Talonz said:I think the only way to kill yourself with caps of these size is to charge them up and stab the ends with a finger from each hand. Maybe it will stop your heart?![]()
