Danger Den Maze4 low profile
kbussen
I just bought a Danger Den Maze4 low pro from a member the other day. I went to Danger Den website and read the compatibility sheet and it doesnt have my card listed. Does anyone have this GPU water block and know if I will be able to use it on my 7950GT? Maybe modded some how or should I be alright. Thanks.
Also, Will a Swiftech MCP650 pump do well with a GPU, CPU, Chipset and Ram water blocks?
You'll have to trim down whatever heatsink blocks you use on the memory chips that are under the barbs. Not a big deal.
This is the best I could find for Maze4 GPU compatibility:
http://www.dangerden.com/store/image.php?type=D&id=155?1192633227828
I honestly forget if 6x00 and 7x00 series have different mounting holes or not, the only mention I could find from some quick searching was that DD says Maze5 GPU won't fit 7950GT AGP version, and both GPU blocks look to have the same mounting holes.
Your MCP650 is plenty powerful for your loop, unless you have some extremely restrictive other factor in your loop.
Cool thanks for the response. Yeah I figure I can build something if it isnt compatible.
Got it in the mail today. Looks like the 4 holes line up just fine. Thanks for the help guys.
