Danger Den Loop Order?
islanq
Well guys I'm about to cut the holes in my brand new Lian Li PC-75B tomorrow after work and get my liquid installed. I was wondering what you guys thought the best order for my loop to be. Items I will be installing
(1) Danger Den 939 TDX block
(1) Danger Den Maze 4 GPU
(3) Danger Den Black Ice Extreme 120MM radiators (possibly just 2)
(1) Danger Den DD12V-D4 pump
(1) Danger Den single bay res
I was thinking my look should go: pump > rad 1 > rad 2 > rad 3 > cpu block > gpu block > res.
If you guys have any suggestions please let me know.
why do you have 3 rads ? It increases friction and slows down your water ALOT !!
You could've just used 1 360mm rad if you wanted high performance !! or a heatercore
anyways .. I would say the best loop is
CPU > GPU > RES > PUMP > RAD > CPU ...
