Danger Den DDC-2 18w pump speed indication
Lox
Can someone tell me how to get a speed indication from the subject pump?
I've hooked the speed indicator wire up to the CPU power/speed connector on my Asus MB but I don't get any speed indication?
What speed does this pump run, for those of you that get a indication?
This pump is AWESOME, pump's like crazy and is quiet as a church mouse!
Oh, and those that followed my previous thread about replacing all the thermalcrap water parts with real stuff. I was able to replace the internal thermalcrap rad with a Swiftech MCR220. The Rad mount was an integral part of the hard drive bay. So I used my trusty Dremel to cut off the rad mount. Then used 3/4 inch gore-tex joint sealent on the bottom and sides of the new rad and anchored the whole thing to the existing case mounting holes using some small self tapping screws.
For those wondering about Gore-Tex joint sealeant, it is an industrial product used for sealing tank lids etc, made of soft teflon. The stuff I have is 3/4" wide and 1/4" thick and has a sticky back to it. It's very soft a pliable so it's easy to make a little thicker or thinner if need be.
Thanks
Asus Probe reads mine OK using cpu fan connector on the mb (asus a8n32sli) . Typically reports ~4500 rpm. I have the proggie set to load on startup, always like to check the pump is spinning, as you note would never hear it if it stopped. :eek:
Thanks for the reply. For some reason the fan speed indicator's don't seem to work on my board through Nvidia program or Everest. I've got connectors for four or five fans which are all hooked up but they don't show up in the above software proggies? Strange as when I unhooked all the fan (indicators) then Nvidia monitor pops up shows all the fan connections and say's they aren't hooked up, which is correct lol.
Also BIOS does show the cpu fan speed as being around 4200 rpm which seemed a little on the high side for a pump, but it does seem to work.
